Meta Quest 2 Battery Disconnect Prereq
Arthur Shi
crwdns2944109:0crwdnd2944109:0Arthur Shicrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Maw 29, 2025crwdne2944111:0
crwdns2931273:0crwdne2931273:0
crwdns2937801:0crwdne2937801:0
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
crwdns2942287:0crwdne2942287:0
Steps to disconnect the battery for the Meta Quest 2. Prereq guide.
crwdns2944105:0crwdne2944105:0
  1. Meta Quest 2 Battery Disconnect Prereq, Power off your Meta Quest 2: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Battery Disconnect Prereq, Remove the facial interface: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Remove the facial interface: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Battery Disconnect Prereq, Unclip the side straps: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Unclip the side straps: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Unclip the side straps: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Battery Disconnect Prereq, Remove the top strap: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Remove the top strap: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Battery Disconnect Prereq, Remove the head strap: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Remove the head strap: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Battery Disconnect Prereq, Remove the eyepiece trim screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Remove the eyepiece trim screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Battery Disconnect Prereq, Release the eyepiece trim clips: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Release the eyepiece trim clips: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Battery Disconnect Prereq, Reposition the eyepiece trim: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Reposition the eyepiece trim: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Reposition the eyepiece trim: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Battery Disconnect Prereq, Disconnect the face sensor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Disconnect the face sensor: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Disconnect the face sensor: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Battery Disconnect Prereq, Remove the eyepiece trim: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eyepiece trim.
  17. Meta Quest 2 Battery Disconnect Prereq, Reassembly note: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Reassembly note: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Battery Disconnect Prereq, Reassembly note: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Reassembly note: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Reassembly note: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Battery Disconnect Prereq, Remove the front cover screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Remove the front cover screws: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Remove the front cover screws: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Battery Disconnect Prereq, Release the front cover clips: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Release the front cover clips: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Battery Disconnect Prereq, Remove the front cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front cover.
  23. Meta Quest 2 Battery Disconnect Prereq, Disconnect the top right antenna: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Disconnect the top right antenna: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Disconnect the top right antenna: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Battery Disconnect Prereq, Remove the battery cable bracket: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Battery Disconnect Prereq, Disconnect the battery: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Meta Quest 2 Battery Disconnect Prereq, Disconnect the battery: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
301,068 crwdns2915208:0crwdne2915208:0
crwdns2935297:0687crwdne2935297:0
Staff
crwdns2931471:0118crwdne2931471:0
crwdns2935297:022,548crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 60
