Merch Source Projector Entertainment II Motherboard
crwdns2942287:0crwdne2942287:0Follow this guide to repair components on the logic board. All you will need a solder gun and steady hands.
crwdns2944105:0crwdne2944105:0
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
Using your hands, gently pry the top and bottom of the projector casing apart.
Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
Once the ribbon cable is disengaged gently pull the cable off the motherboard.
Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
Solder off all of the connections on the motherboard with a soldering iron.
Once connections are soldered off, the motherboard should be detached and ready for replacement.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
Was wondering if you could help me identify a microchip on the board by the speaker?
Where can I get parts for the projector? I think my board is cooked.
mine acts like it does not recognize the rca cords. help
