Merch Source Projector Entertainment II Light Bulb Replacement
  1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Light Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Light Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
Stephanie
crwdns2935283:001/08/15crwdne2935283:0
282 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-3, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-3, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G3
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,157
