Merch Source Projector Entertainment II Light Bulb Replacement
crwdns2869540:0crwdne2869540:0: 2927
2
17
89
2,927
crwdns2955950:0crwdne2955950:0: 2
crwdns2960002:01crwdne2960002:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    2. Merch Source Projector Entertainment II Light Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
    3. Merch Source Projector Entertainment II Light Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your hands, gently pry the top and bottom of the projector casing apart.
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
Stephanie
crwdns2935283:001/08/15crwdne2935283:0
282 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-3, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-3, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G3
crwdns2935297:048crwdne2935297:0
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 89
crwdns2959996:0crwdne2959996:0 2,927
