A common problem seen in the 2000s Mercedes-Benz is the pull handle breaks off fairly easily with time. This is the full replacement guide for the pull handle of a 2007 Mercedes-Benz c230. The inability to use the pull handle makes it awkward and difficult to close the car door once inside.
This guide can be followed with most Mercedes-Benz models, including: C-Class, W203, C230, C240, C280, C320, C350, C32 AMG, and C55 AMG.
Please make sure to open the window before starting because it will make the steps go by a lot easier.
WARNING: MAKE SURE CAR IS TURNED OFF BEFORE STARTING THE REPLACEMENT
Use a spudger to pry off the cover of the pull handle.
Use a spudger to pry off the SRS Airbag Badge.
Use the T30 Torx Driver to remove the two screws located inside the pull handle.
Use the T30 Torx Driver to remove the screw behind the SRS Airbag Badge.
Use the T20 Torx Driver to remove the screw on the lock knob.
Use the Door Upholstery Remover to pry off the door panel from the metal door frame.
After separating the door panel from the metal, gently pull the door panel away from the metal door frame from the sides and bottom to loosen the nails.
Pull the rubber off the wire of the door handle latch cable.
Pull off from fasten.
Unhook the door handle latch cable
Use the T20 Torx Screwdriver to remove the screws on the pull handle.
Use Flathead 3/32" or 2.5 mm Screwdriver to press the clips on the side of the pull handle piece.
These are the clips.
Place the new pull handle in place.
Use the T30 Torx Screwdriver to fasten the new pull handle.
