Mercedes W123 Fuel Primer Pump Replacement
  1. Mercedes W123 Fuel Primer Pump Replacement, Fuel Primer Pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Seen here is the original primer pump on this 1979 300CD. It is an older style that has become prone to leaking after all these years. We are going to replace it with an updated style by Bosch.
  2. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the fuel in the cavity on top of the pump. This pump was definitely leaking. Most of them do these days.
  3. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the old primer pump is simply a matter of finding the proper wrench to either grab the flat sides at the base of the pump, or using a vice grip to grab the body of the pump. An offset wrench like pictured can be very helpful. Since the pump is being replaced it doesn't matter too much if the vice grips damage the pump.
    • Note that clearance can be a bit tight down by the primer due to fuel and power steering fluid lines in the area. However, if you're patient, you'll find a way to get the tools on and turn off the pump.
    • Note that there seems to be variation in the size of wrench these primer pumps take. The offset wrench I have is a 19mm which worked on a pump on another car, but was too small for this car. So I used vice grips.
  4. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Under the old primer pump will be a copper crush washer. This must be removed before installing the new pump as you'll be installing a new crush washer. Use a small flat blade screw driver to gently push and pry on this washer to remove it.
  5. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is the old primer pump removed from the car. You can see the minimal damage that the vice grips did to the body of it. Also, in the second picture, you can see how wet, discolored, and dirty the pump knob is. This is from leaking fuel.
  6. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is the updated style pump. It uses a simple plunger and should prove simple and reliable to use.
    • The threaded end of the primer pump is protected in the box by a yellow plastic cap. Underneath the cap is the new copper crush washer. Be sure not to drop it and let it roll away!
  7. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully use a shop towel to wipe any dirt out and away from the opening in the lift pump, then install the new crush washer.
  8. Mercedes W123 Fuel Primer Pump Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now screw the new primer pump in by hand as far as you can, then use a wrench (the new ones take a 17mm) to snug it down. There is no need to wrench on it really heavily, just turn it until you feel resistance as the crush washer deforms to create a seal under the pump.
When you've finished run your engine and check for leaks. If it is leaking at the base, where the pump screws in, the crush washer is not fully crushed. Tighten it down a little more.
crwdns2935229:016crwdne2935229:0
Nicolas Siemsen
crwdns2935283:012/06/13crwdne2935283:0
39.953 crwdns2915208:0crwdne2915208:0
crwdns2935297:079crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01.422crwdne2935297:0
Unfortunately, wasn't much help with my 83 300D, because the pump and fittings are reversed. Which makes it very difficult to get to the pump to tighten it down, with the brass fittings in the way. So if your setup doesn't look like the pictures above, you're going to have to do some extra work to get it done.
jamesrasbeary - crwdns2934203:0crwdne2934203:0
Yes, mine too… Most odd - a lot more work getting it sorted. Thanks for the write up though.
Bruce Wright - crwdns2934203:0crwdne2934203:0
Hi,
I lost the little plastic piece goes under the primer pump, and therefore the pump doesn’t work properly. What is this piece, and where can I find a new one?
Nicholas Otten - crwdns2934203:0crwdne2934203:0
Mine is different as well, only 2 nuts/ studs holding the body on most seem to have 3. My 2 brass fittings also make it more difficult.
Shaun James - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 122
crwdns2942667:0crwdne2942667:0 21,511
