Mercedes W123 Brake Line, Rear Replacement
  1. Mercedes W123 Brake Line, Rear Replacement, Brake Line, Rear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Brake Line, Rear Replacement, Brake Line, Rear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before beginning to remove the hard brake lines you'll need to drain the fluid from your rear caliper(s). You only need to drain the fluid from the side you're working on; if you're doing both lines, drain both.
    • To drain them loosen the bleed screw and let the fluid drip in to a pan.
  2. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Spray the area where the hard brake lines and the soft rubber hoses connect at the rear of the car with penetrating lubricant.
  3. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the brake line distributor at the rear of the car where the two hard lines split off to each wheel. It is just up behind the driver's side axle.
    • Spray this with penetrating lubricant.
    • The components shown include:
    • Hard line to front of car, connects to master cylinder.
    • Hard line to rear driver's side caliper.
    • Hard line to rear passenger side caliper.
    • Distributor.
  4. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This guide will start on the driver's side line. You may begin on either side.
    • Begin by removing the soft rubber hose where it connects to the hard line.
    • For information on removing these soft rubber hoses see the rubber brake hose removal guide. Consider replacing these hoses at this time since you already have them disconnected halfway.
  5. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 11mm line wrench or open end wrench to loosen the connection for the driver's side brake line at the distributor.
    • This line can then be removed from the car.
  6. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat with the passenger side line. Loosen it from the distributor.
    • Note that this line may be routed through a bracket that holds both the hard brake line and the hard fuel line from the fuel tank in place with a rubber buffer. This is located directly up from and behind the rear differential.
    • If you find this on your car, loosen the 10mm bolt on the bracket. You do not need to fully remove the bracket, just loosen it enough that it releases the brake line. It can then be pulled out of the car.
  7. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your distributor will now look like this.
  8. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now begin installing the new lines.
    • Starting with the passenger side line, note that it should go in behind the rubber drain hose just inside the rear fender.
    • The driver's side simply sets in place as the old line did.
  9. Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mercedes W123 Brake Line, Rear Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean all the end connections of the hard lines, at the distributor and at the brackets for the soft rubber hose connection, with brake cleaner to remove any dirt. You do not want to introduce dirt in to your brake system.
    • Let the brake cleaner dry. You can then begin reconnecting the soft rubber hoses, and can connect the hard lines to the distributor.
    • Before driving your car you will need to bleed the system to remove the air that has been introduced. Never drive your car after doing work on the brake lines without first bleeding it properly. See the brake flush/bleeding guide for help with this.
Nicolas Siemsen
crwdns2935283:012/06/13crwdne2935283:0
39.866 crwdns2915208:0crwdne2915208:0
crwdns2935297:079crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01.685crwdne2935297:0
Hi,
I need to change my hard brake lines on my 1981 Mercedes 300SD. I need to change the rear hard brake line (coming from master cylinder) and 2 rear hard brake lines at the distributor. Where can I buy/order those hard brake lines? What are the specs on them? Can I make them myself?
Thank you
Vito - crwdns2934203:0crwdne2934203:0
I am having the same issue. did you ever find out where to order the hard brake lines?
Jacob Clary -
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 8,349
