Mercedes W123 Battery Ground Cable Replacement
  1. Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by disconnecting both battery terminals, beginning with the negative (-) side, which travels just a few inches to a bolt attaching the other end to the car's body.
    • Never remove your positive (+) cable first or you risk injury from electric shock.
  2. Mercedes W123 Battery Ground Cable Replacement, Remove the old ground cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove this 13mm bolt that holds the cable to the metal of the car's chassis.
    • Now remove the old ground cable.
  3. Mercedes W123 Battery Ground Cable Replacement, Install the new cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mercedes W123 Battery Ground Cable Replacement, Install the new cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can see here that the new ground cable is substantially thicker. It is a 2 gage cable. The ends are also crimped better, protecting the inner wire from corrosion.
    • This cable is also a bit longer than the old one, giving some more wiggle room.
  4. Mercedes W123 Battery Ground Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new ground cable, using the new captive bolt, and nut, that came with it.
    after replacing this ground cable my tach started working again! I can’t say enough about cleaning grounds and contacts/connections in general.  A cheap and easy way to solve some common electrical issues
    Bob - crwdns2934203:0crwdne2934203:0
    I would recommend using a small brass brush to clean the area on the chassis where the bolt makes contact. Having a clean ground will help in so many ways to eliminate electrical gremlins.
    Andrew Lisenby - crwdns2934203:0crwdne2934203:0
Once you've finished, consider covering the terminal where the cable attaches to the battery in a silicone dielectric grease to prevent corrosion.
crwdns2935229:012crwdne2935229:0
Nicolas Siemsen
crwdns2935283:012/06/13crwdne2935283:0
39,893 crwdns2915208:0crwdne2915208:0
crwdns2935297:079crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,703crwdne2935297:0
Problem de masse cable du batterie moins voiture Mercedes binz c180
Hamateegandawel@gmail.com - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 9,656
