You may find that the boombox is not recognizing or charging your iPod. This guide demonstrates how to replace the iPod adapter if your original adapter fails. It also involves extensive unscrewing and disassembly of the device.
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Use a Phillips #1 screwdriver to remove the two 12 mm screws.
Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
Remove the two 8 mm screws with a Phillips #1 screwdriver.
Remove the two 12 mm screws with a long Phillips #1 screwdriver.
To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
Carefully pull the panel off.
Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
Use the Phillips #1 screwdriver to remove the four 12 mm screws.
Remove the five 6 mm screws at the top with the same screwdriver.
Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
Use moderate force to pry it open and take the cover off.
Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device.
Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors.
Follow the wires attaching to the iPod adapter and use the IC (Integrated Circuit) extractor to remove the indicated wire connectors from the motherboard.
Pinch the IC extractor just under the top lip of the wire housing.
Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver.
Remove the iPod adapter by sliding it out of the slot.
