Melitta Caffeo Barista T opening
  1. Melitta Caffeo Barista T opening, Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Never forget: Remove the cable from the powerplug
    • Remove all the parts
  2. Melitta Caffeo Barista T opening, Remove the backside: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T opening, Remove the backside: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The backside is fixed with seven Torx T10 screws. Unscrew them
    • Get the Backside of. It should be a bit stuck.
  3. Melitta Caffeo Barista T opening, Remove the powder compartment lid: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T opening, Remove the powder compartment lid: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T opening, Remove the powder compartment lid: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the powder compartment up.
    • Pull one of the sides of the Powder compartment out of the hinge and loosen the lid.
    • Remove the powder compartment
  4. Melitta Caffeo Barista T opening, Loosen the upper housing part: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T opening, Loosen the upper housing part: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T opening, Loosen the upper housing part: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the powder compartment, you should see a rubber cover. Loosen the rubber cover with the appropriate tools.
    • There should also be a Torx T10 screw. Unscrew it
  5. Melitta Caffeo Barista T opening, loosening the Upper housing part: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T opening, loosening the Upper housing part: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The upper cover with the brewing unit is held up from three clamps. These can be reached through a slit.
    • Press these clams with a flat scredriver in and pull the upper cover up, until the clamps loosen.
  6. Melitta Caffeo Barista T opening, Removal of the upper case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T opening, Removal of the upper case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T opening, Removal of the upper case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the side that has a a watertank you can find 2 other clamps
    • Press these clamps with a flat scredriver in and pull the cover up until they loosen
    • Lift the upper cover and the backside up, hook it on the front edge and remove them
  7. Melitta Caffeo Barista T opening, Removal of the side panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T opening, Removal of the side panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the right and the left side panel back, then pull the lower edge out and pull the side panel out.
    • This could be a bit stuck
    • On the side panel with the watertank, there should be a supply hose attached to a cable that connects the water-level sensore. loosen them
    • Hint: the side panel doesn't have to be removed completely for each repair.
Work through the steps in reverse order, to rebuild your machine.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
285,070 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:031crwdne2931471:0
crwdns2935297:01,549crwdne2935297:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 210
crwdns2942667:0crwdne2942667:0 4,863
