Melitta Caffeo Barista T Grinder removal
  1. Melitta Caffeo Barista T Grinder removal, Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Never forget: Remove the cable from the powerplug
    • Remove all the parts
  2. Melitta Caffeo Barista T Grinder removal, Remove the backside: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Remove the backside: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The backside is fixed with seven Torx T10 screws. Unscrew them
    • Get the Backside of. It should be a bit stuck.
  3. Melitta Caffeo Barista T Grinder removal, Remove the powder compartment lid: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Remove the powder compartment lid: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Remove the powder compartment lid: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the powder compartment up.
    • Pull one of the sides of the Powder compartment out of the hinge and loosen the lid.
    • Remove the powder compartment
  4. Melitta Caffeo Barista T Grinder removal, Loosen the upper housing part: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Loosen the upper housing part: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Loosen the upper housing part: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the powder compartment, you should see a rubber cover. Loosen the rubber cover with the appropriate tools.
    • There should also be a Torx T10 screw. Unscrew it
  5. Melitta Caffeo Barista T Grinder removal, loosening the Upper housing part: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, loosening the Upper housing part: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The upper cover with the brewing unit is held up from three clamps. These can be reached through a slit.
    • Press these clams with a flat scredriver in and pull the upper cover up, until the clamps loosen.
  6. Melitta Caffeo Barista T Grinder removal, Removal of the upper case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Removal of the upper case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Removal of the upper case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the side that has a a watertank you can find 2 other clamps
    • Press these clamps with a flat scredriver in and pull the cover up until they loosen
    • Lift the upper cover and the backside up, hook it on the front edge and remove them
  7. Melitta Caffeo Barista T Grinder removal, Removal of the side panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Removal of the side panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the right and the left side panel back, then pull the lower edge out and pull the side panel out.
    • This could be a bit stuck
    • On the side panel with the watertank, there should be a supply hose attached to a cable that connects the water-level sensore. loosen them
    • Hint: the side panel doesn't have to be removed completely for each repair.
  8. Melitta Caffeo Barista T Grinder removal, Remove bean compartment: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Remove bean compartment: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 3x Torx T10 screws that secure the bean compartment.
    • Remove the bean compartment upwards.
    • When assembling, make sure that the slider for setting the bean type engages properly.
  9. Melitta Caffeo Barista T Grinder removal, Expose grinder: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Expose grinder: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Expose grinder: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the two foam dampers and the black rubber bean feeder.
  10. Melitta Caffeo Barista T Grinder removal, Remove powder chute: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Melitta Caffeo Barista T Grinder removal, Remove powder chute: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the Torx T10 screw that secures the powder chute.
    • Lift out the powder chute.
  11. Melitta Caffeo Barista T Grinder removal, Lift out the grinder: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The grinder is fixed with 3x Torx T10 screws. Unscrew them.
    • Now the grinder is loose. Press it inward a little so that the previously mentioned adjustment lever is free and lift the grinder upward a little.
    • If you want to replace it completely, you still need to disconnect the two cables, if you just want to clean it or replace the grinding stones, it is not necessary.
Follow these steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
261.844 crwdns2915208:0crwdne2915208:0
crwdns2935297:0297crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:030crwdne2931471:0
crwdns2935297:01.813crwdne2935297:0
Sehr ausführlich, jetzt geht meine Kaffeemaschine wieder, dabei war ich schon etwas hilflos, vielen Dank !
chiara lo - crwdns2934203:0crwdne2934203:0
Acabo de leerlo. Me parece un trabajo Excelente por su parte. Me pondré manos a la obra. Seguro que me ha solucionado. Mucha Salud y Mucha Suerte. Muchas Gracias.
Emilio - crwdns2934203:0crwdne2934203:0
Eine Frage: Hat auch dieses Mahlwerk das "Problem", das viel Pulver liegen bleibt ? also das erste mahlen gibt keinen Kaffee da das Kaffeemehl "liegen" bleibt und erst der zweite Mahlvorgang, das Kaffeemehl des ersten Malvorganges dann in der Brühgruppe landet ?
Rene Hegewald - crwdns2934203:0crwdne2934203:0
Naja: es gibt einen kleinen Kanal zwischen Mahlwerk und Brühgruppe. Da liegt Kaffeemehl für eine knappe Tasse drin. Nach dem Ausbau wird also erst die zweite Tasse gut, nach sehr langer Standzeit schmeckt die zweite Tasse besser.
VauWeh -
crwdns2936753:07crwdne2936753:0 108
crwdns2936753:030crwdne2936753:0 399
crwdns2942667:0crwdne2942667:0 6,517
