This guide demonstrates how to easily replace the battery in a Medtronic 670G Insulin Pump. Replacing the battery of this device is important so that that the device can regulate your insulin and blood sugar as needed. It is crucial for the user to keep track of their health needs. I hope that with this guide will help you on the maintenance of your device.
Detach the clip on the back of the device.
Place the small protrusion on the bottom of the clip into the slot on top of the battery housing, and turn it counter clockwise.
Remove the battery cap.
Dispose of the old battery according to your state guidelines.
Insert the new battery, making sure the negative end (the flat part of the battery) is facing down.
Replace the battery cap tighten until it is aligned.
Turn on the pump and wait until the HOME screen load to make sure the battery is working.
Your Medtronic 670G insulin pump is good-to-go!
Need one badly
