Mazda 323 BG Dashboard Replacement
  1. Mazda 323 BG Dashboard Replacement, Mazda 323 BG Dashboard Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Upgrading your Dashboard or what ever, you might want to open your Dashboard, this is the Easy Way...
  2. Mazda 323 BG Dashboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mazda 323 BG Dashboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mazda 323 BG Dashboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open your door, you will see a Plastic Cover, remove it with a screwdriver or by hand.
  3. Mazda 323 BG Dashboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mazda 323 BG Dashboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mazda 323 BG Dashboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 screws holding the cover in place.
  4. Mazda 323 BG Dashboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws above of the Dashboard.
  5. Mazda 323 BG Dashboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now to the magic: usualy, one must remove the steering wheel in order to continue. There are 2 easy alternatives:
  6. Mazda 323 BG Dashboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Option 1: With height adjustable steering wheel: remove the screw holding the top steering column trim and lower the column to its lowest by releasing the lever. Remove the top steering column trim.
  7. Mazda 323 BG Dashboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mazda 323 BG Dashboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Option 2: Without height adjustable steering column: Remove all 4 screws of the steering column trim. Afterwards: remove the large golden screws. Be carefull whilst removing the last one: hold the column tight with one hand or it will fall, since it is screwed to nothing else.
  8. Mazda 323 BG Dashboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After Option 1 or 2: Pull the trim out of its holding clips. Disconnect all wires, except for clock and hazard switch. Slowly remove the trim, in case of Option 1: you might have to slightly bend the trim, be carefull. Afterwards: Rotate the trim 180° around the clock wire.
  9. Mazda 323 BG Dashboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally: Remove the 4 screws holding the dashboard. Disconnect the 3 connectors and speed wire and you are done!
Frank
crwdns2935283:012/21/17crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
That’s not the dashboard that’s a cluster removal
Matthew Canavan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,466
