Mayflash Arcade Stick F300 Joystick Replacement
  1. Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Joystick Replacement, Joystick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement, Joystick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the micro switch cables connected to the PCB (printed circuit board).
  3. Mayflash Arcade Stick F300 Joystick Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to hold the bottom screw of the joystick lever in place.
    • Flip the device over.
    • Grab the ball top of the joystick and twist while the screwdriver prevents the screw from turning.
    • Once the ball top is removed, slide off the plastic tube and plate from the joystick.
  4. Mayflash Arcade Stick F300 Joystick Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mayflash Arcade Stick F300 Joystick Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over again, exposing the inside.
    • Use a Phillips #1 screwdriver to remove the four screws holding down the joystick lever.
    • Slide the joystick out of the outer plastic casing.
Jess Anderson
crwdns2935283:009/04/24crwdne2935283:0
327 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-4, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-4, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G4
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 436
