MaxWest TAB-7360DC Battery Replacement
  1. MaxWest TAB-7360DC Battery Replacement, Back Hard Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MaxWest TAB-7360DC Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
Gillian Bundles
crwdns2935283:003/21/18crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
IUPUI, Team S4-G3, Baechle Spring 2018 crwdns2935289:0IUPUI, Team S4-G3, Baechle Spring 2018crwdne2935289:0
IUPUI-BAECHLE-S18S4G3
crwdns2942667:0crwdne2942667:0 1,874
