The Matsunichi M97 is a useful tablet for anyone. The battery of the tablet is a crucial part of the device. The battery might need to be replaced if the device does not charge or turn on this may be a sign of a battery failure. Most other components on the M97 tablet are obstructed by the battery so the removal of the battery is a necessary first step for most other replacements. Battery replacement requires no special skills and is the simplest replacement on the M97 tablet..
Open the micro SD cover located on the back of the device.
Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
Use the iFixit opening tool to pry off the back cover of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to disconnect the battery from the motherboard.
Carefully unstick the battery from the frame using the spudger.
