If your device is not connecting properly, it might be necessary to replace the Bluetooth wireless connector. This guide will show 7 steps for removing the wireless connector. Soldering is required for this replacement, If you don't know how to solder, click here for a great guide.
Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
Use the Jimmy to lift up the black cover to get inside the device.
Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
Move the side cover off to the side.
Pull the black tape holding the connector in place.
Desolder the connector from the motherboard.
Solder the new Bluetooth connector into place.
