You will want to disassemble the Left side of the headphones. This guide requires soldering, If you don't know how to solder, click here for a great guide.
Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
Use the Jimmy to lift up the black cover to get inside the device.
Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
Move the side cover off to the side.
Desolder all the wires connected to the motherboard.
Remove the two 2mm screws holding the motherboard in place.
To reassemble your device, follow these instructions in reverse order. You may want to use the picture from Step 5 to correctly re-solder your device.
