Follow this guide to replace the woofer inside your MartinLogan Motion 4i model MO4IBL.
The woofer in a speaker generates low frequencies. A speaker with a failing woofer makes a fizzing sound.
You must have the back cover removed from the Speaker to start repairs. If you have already removed the back cover, please skip to step 7.
In step 9 you will need a soldering iron to take out 2 wires off the woofer.
Before beginning, the woofer is highly magnetic so keep your phone and other electronic devices away from it
Remove the speaker grill from the face of the speaker by using both hands to grip both ends of the speaker grill and pulling up to release the magnetic ends.
Remove the six caps from the outer edge of the face of the speaker with an iFixit opening tool.
Remove the six 4 mm Phillips #2 screws that are located inside each of the holes where the rubber caps used to be.
Place the device face-down, then lift off the back case with both hands.
Lightly grip the material that insulates and covers the speaker components and remove it by pulling up.
Remove both wires that are connecting the back of the speaker to the components of the speaker to fully access the speaker components.
Remove the 3 mm Phillips #2 screws around the woofer.
Lift the woofer out of the speaker base.
