Martian Victory Motherboard Replacement
  1. Martian Victory Motherboard  Replacement, Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Martian Victory Motherboard  Replacement, Back Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Motherboard  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Motherboard  Replacement, Lithium Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Motherboard  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Motherboard  Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Motherboard  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Motherboard  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Motherboard  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Martian Victory Motherboard  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Martian Victory Motherboard  Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Motherboard  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Martian Victory Motherboard  Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
Dominic Coffey
crwdns2935283:010/24/16crwdne2935283:0
243 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 3-3, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S3G3
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 268
