Martian Victory LED Screen Replacement
  1. Martian Victory LED Screen Replacement, Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Martian Victory LED Screen Replacement, Back Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Martian Victory LED Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Martian Victory LED Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
Robert Sanchez
crwdns2935283:010/31/16crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 3-3, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S3G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 295
