Marshall Woburn Subwoofer Replacement
  1. Marshall Woburn Subwoofer Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Woburn Subwoofer Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Subwoofer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Woburn Subwoofer Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Subwoofer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn Subwoofer Replacement, I/O Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the 5 wires circled in red from the back input board.
    • Grip and pull the connectors, not the wires.
    • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
  5. Marshall Woburn Subwoofer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Woburn Subwoofer Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn Subwoofer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely remove the I/O board and the attached plate.
  7. Marshall Woburn Subwoofer Replacement, Subwoofer: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
  8. Marshall Woburn Subwoofer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift each subwoofer up and out of the case and remove them together.
    • This may require a little force.
Kenneth
crwdns2935283:010/29/23crwdne2935283:0
174 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023crwdne2935289:0
UMASSD-GULBRANDSEN-F23S2G4
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 1,430
