Marshall Uxbridge LED Board Replacement
  1. Marshall Uxbridge LED Board Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Uxbridge LED Board Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Uxbridge LED Board Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient your speaker so that the back is facing you.
    • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
    • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
  2. Marshall Uxbridge LED Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Uxbridge LED Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the white connector from inside the bottom of the back panel.
    • Detach the small red and white connectors from the motherboard on the left side of the back panel.
  3. Marshall Uxbridge LED Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the blue ribbon cables from the motherboard.
    • Remove the back panel from the speaker base.
  4. Marshall Uxbridge LED Board Replacement, LED Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Uxbridge LED Board Replacement, LED Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the bottom of the speaker to face away from you.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws holding the power relay in place.
  5. Marshall Uxbridge LED Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Uxbridge LED Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the power relay from the speaker.
    • Slide out the blue ribbon cable from the power relay.
    • Put the power relay to the side.
  6. Marshall Uxbridge LED Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6 mm screws connected to the LED board using a TR9 Torx screwdriver.
  7. Marshall Uxbridge LED Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Uxbridge LED Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the blue ribbon cable to lift the LED board.
    • Pull the blue ribbon cable out of the LED board.
Angie Delgado
crwdns2935283:009/06/24crwdne2935283:0
390 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Fall 2024 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Fall 2024crwdne2935289:0
WCU-VIRTUE-F24S1G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 81
