Marshall Stanmore II Tweeter Assembly Replacement
  1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
  2. Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
  3. Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
  4. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
  5. Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
    • Repeat for the second connector.
  6. Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
    • Lift the tweeter assembly from its housing.
  7. Marshall Stanmore II Tweeter Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
    • Repeat steps 4-6 to remove the second tweeter if necessary.
Jacob Rose Parks
crwdns2935283:002/06/24crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-1, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-1, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G1
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 379
