Marshall Stanmore II Subwoofer Assembly Replacement
  1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
  2. Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
  3. Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
  4. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back the clear sheaths on the end of each wire to expose the terminals.
    • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
    • Failure to press the latch while pulling could damage the subwoofer and/or wires.
  5. Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
    • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
  6. Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the subwoofer assembly away from the housing.
  7. Marshall Stanmore II Subwoofer Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
Rebecca Arellano
crwdns2935283:002/05/24crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-1, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-1, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G1
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 717
