Marshall Stanmore II Power Switch Replacement
  1. Marshall Stanmore II Power Switch Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Power Switch Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
  2. Marshall Stanmore II Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Power Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
  3. Marshall Stanmore II Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Power Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
  4. Marshall Stanmore II Power Switch Replacement, Power Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Power Switch Replacement, Power Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Power Switch Replacement, Power Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the Power Switch PCB on the left-hand side above the subwoofer.
    • Use a Phillips #2 screwdriver to remove the two 10 mm screws that secure the PCB.
    • Because the space inside is somewhat cramped, consider using the iFixit 150 mm Flex Extension included in the iFixit Pro Tech Toolkit.
  5. Marshall Stanmore II Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II Power Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the PCB's black wire connector and gently disconnect it.
    • Do not pull on the wires.
  6. Marshall Stanmore II Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Power Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II Power Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the PCB out of the mount.
    • Take care not to damage the rubber seal surrounding the switch base as depicted in picture two.
    • Rocking the PCB back and forth while pulling may help remove the module.
Jacob Rose Parks
crwdns2935283:002/06/24crwdne2935283:0
527 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-1, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-1, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G1
Hellooooo very good but were did you fint the eplace the power switch ?
Fred - crwdns2934203:0crwdne2934203:0
Where can buy on /off switch ?
Choi Kee - crwdns2934203:0crwdne2934203:0
On/off switch bar is broken
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 127
crwdns2942667:0crwdne2942667:0 2,006
