Marshall Stanmore II AUX Board Replacement
  1. Marshall Stanmore II AUX Board Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II AUX Board Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
  2. Marshall Stanmore II AUX Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
  3. Marshall Stanmore II AUX Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
  4. Marshall Stanmore II AUX Board Replacement, AUX Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II AUX Board Replacement, AUX Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the AUX board on the right-hand side, above the subwoofer.
  5. Marshall Stanmore II AUX Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 9.6 mm screws that secure the AUX board to the speaker frame.
    • Since the screws are awkwardly located, using the 150 mm Flex Extension is recommended.
  6. Marshall Stanmore II AUX Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the red and white cable connected to the AUX board by hand or with tweezers.
    • Do not pull on the wires.
  7. Marshall Stanmore II AUX Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the speaker around with the knobs facing you and unscrew the threaded washer that secures the AUX module to the outer plate.
    • The washer can be removed by hand or with tweezers.
    • Since it is disconnected from inside the frame, the AUX board may loosen enough to fall after removing the washer.
  8. Marshall Stanmore II AUX Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Stanmore II AUX Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the AUX board from inside the speaker.
Jacob Rose Parks
crwdns2935283:002/06/24crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-1, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-1, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G1
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 644
