Marshall Kilburn Main Speaker Replacement
  1. Marshall Kilburn Main Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn Main Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the unit face down as shown in the picture, exposing the battery cover.
    • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
  2. Marshall Kilburn Main Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover using a fingernail or nylon spudger.
  3. Marshall Kilburn Main Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and unplug the power lead.
  4. Marshall Kilburn Main Speaker Replacement, Power Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement, Power Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement, Power Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
    • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
  5. Marshall Kilburn Main Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover by using the vent hole as a grip.
    • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
    • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
  6. Marshall Kilburn Main Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the back cover attached to the motherboard to the side as shown in first image.
    • Remove the white insulator from the stereo speaker and place it to the side.
    Hi can you post a picture with the full PCB please i want to compare it with mine. Thank you.
    Attila Fustos - crwdns2934203:0crwdne2934203:0
  7. Marshall Kilburn Main Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
    • Gently pull out the power switch as shown in the image.
  8. Marshall Kilburn Main Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a slim spudger to wedge out the four red wires attached to the power switch.
  9. Marshall Kilburn Main Speaker Replacement, Main Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement, Main Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement, Main Speaker: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the eight 22.5mm screws of the speaker cover and the device using a Phillips #2 screwdriver.
    • Gently push the speaker cover out of the stereo speaker.
    • Make sure to slowly push out the speaker cover, and not too far because it is still connected to the stereo speaker.
  10. Marshall Kilburn Main Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the blue wires connected to the tweeter.
    • Disconnect the yellow wires connected to the main speaker.
    • Disconnect the red wires connected to the second tweeter.
  11. Marshall Kilburn Main Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshall Kilburn Main Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 13.5mm screws connecting the main speaker to the speaker cover, with a Phillips #2 screwdriver.
    Hi there
    I have marshall woburn works for 4 years
    but now there is crackling sounds after i turn it on for 5 mins and it came from the left side of the speaker , any suggestion?
    jayanis dhamrattana - crwdns2934203:0crwdne2934203:0
Jeff Feuss
crwdns2935283:001/14/19crwdne2935283:0
450 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S1-G3, Lancaster Winter 2019 crwdns2935289:0Oregon Institute of Technology, Team S1-G3, Lancaster Winter 2019crwdne2935289:0
OIT-LANCASTER-W19S1G3
crwdns2947412:010crwdne2947412:0
Google search doesn’t give many results for replacement speakers. Where did you get your replacement speaker? Thanks.
texasbluezman - crwdns2934203:0crwdne2934203:0
Yes, this is an old post, thread. The speaker has mono midrange, bass and stereo treble. The speaker in the center is also a midrange. If you replace it with another type of speaker of the same size, you will change the sound. The sound can quickly become worse.
Fordium -
I am looking for the replacement Speaker as well
Sean G - crwdns2934203:0crwdne2934203:0
The device page has a couple of references that could help you find purchasing information on The Marshall Kilburn.
Jeff Feuss - crwdns2934203:0crwdne2934203:0
I’m also looking for the replacement speaker. Jeff Feuss, you mentioned the “device page,” but I’m not sure where this is (I just joined this site). I get the point of “ifixit,” but I’m ready to call in some help on the repair at this point. I’m going on a year of trying to get my speaker back in working condition. I’ve tried the third party location where I purchased it, BestBuy (wouldn’t service it), and a local electronics repair company. Marshall has been absolutely no help; they only service the Kilburn (1st gen) at the center in England. However, they require the originating address to be in England (won’t return the speaker outside of England). I’m currently seeking friends that live in England. :-)
Julian Philip Cunningham - crwdns2934203:0crwdne2934203:0
im after a mainboard if someone wants to sell me theirs
andrew graham - crwdns2934203:0crwdne2934203:0
I guess throw it away and spend another 350.00 because nobody can find a 25.00 dollar speaker.
Daniel Sargent - crwdns2934203:0crwdne2934203:0
hi, thks for the guide. Do you know what's the size of the main speaker ?
B Z - crwdns2934203:0crwdne2934203:0
Fordium - crwdns2934203:0crwdne2934203:0
Hello. I would much rather be interested in the battery indicator mod. Amazing that the speaker only has 1 battery light and no more. You know when the battery is fully charged or empty but nothing more. Useless. also no battery meter over bluetooth.
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 13,653
