Marshal Woburn Top Control Panel Replacement
    1. Marshal Woburn Top Control Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshal Woburn Top Control Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
      • On a flat surface, orient the device so that the front grille is facing downward.
      • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
      • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
    2. Marshal Woburn Top Control Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshal Woburn Top Control Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the back input board slightly above the back panel.
      • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
      • Fully slide the input board through the back panel and set it down gently inside the speaker.
    3. Marshal Woburn Top Control Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grab the panel by the large hole and lift one side until you can fit your hand under.
      • Use your hand to fully remove the back panel from the rest of the frame.
    1. Marshal Woburn Top Control Panel Replacement, I/O Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the 5 wires circled in red from the back input board.
      • Grip and pull the connectors, not the wires.
      • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
    2. Marshal Woburn Top Control Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marshal Woburn Top Control Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
      • Remove the power input from the back side of the panel.
    3. Marshal Woburn Top Control Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely remove the I/O board and the attached plate.
    1. Marshal Woburn Top Control Panel Replacement, Top Control Panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Philips #1 screwdriver, remove the eight 9.5 mm screws that are marked in red from the perimeter of the metal frame for the top control panel.
    2. Marshal Woburn Top Control Panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • From the outside of the speaker, push down on the top control panel until you can feel the adhesive holding it to the frame start to loosen.
      • On the inside, make your way around the border of the top control panel and remove the adhesive until you can fully remove the panel from the frame.
NateP
crwdns2935283:011/01/23crwdne2935283:0
284 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023crwdne2935289:0
UMASSD-GULBRANDSEN-F23S2G4
Hi. The on off switch has broken on my Woburn 2. Any ideas how to replace it and where I could buy a new switch? Thank you.
mathew jones - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 1,125
