Marsback Zephyr Pro Fan Replacement
  1. Marsback Zephyr Pro Fan Replacement, Removing Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by removing the 2 screws on the bottom of the mouse.
    • You can either remove the rear skate and re-adhere it afterwards or use a 9/64" or 3.5mm drill bit to reveal the holes
    • If you opt to drill a hole through the skate, pressing hard in the area will reveal a indentation where the hole lies
  2. Marsback Zephyr Pro Fan Replacement, Freeing the Shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marsback Zephyr Pro Fan Replacement, Freeing the Shell: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marsback Zephyr Pro Fan Replacement, Freeing the Shell: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, pull the bottom of the shell slightly apart to create clearance
    • Next, wiggle the bottom of the mouse's base left and right while pulling down
    • Once the locking pieces at the top are free, the base of the mouse will be detached from the top shell
    • Do not fully remove the halves until the ribbon cable between them has been disconnected
  3. Marsback Zephyr Pro Fan Replacement, Replacing the Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marsback Zephyr Pro Fan Replacement, Replacing the Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marsback Zephyr Pro Fan Replacement, Replacing the Fan: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the top shell to the right.
    • Optionally disconnect the ribbon cable to give extra working space by pulling up on the ribbon cable connector's locking piece until the ribbon cable can freely slide out.
    • Unscrew the 2 screws holding in the fan and pull the fan connector out. There is no locking mechanism on the fan connector.
    • If the new fan doesn't have the correct DC connector, you may want to salvage the original fan's connector and solder it onto the new fan. If soldering on a connector, ensure the positive (red) side from the fan ends up on the left when the connector is plugged into the mouse.
    • Slide the new fan onto the mounting posts and replace the screws.
    • Reconnect the fan connector. Ensure the positive side (red) of the fan cable is on the left.
    • Reconnect the top shell ribbon cable and press down the locking tab fully before reassembling the mouse.
    • Before reassembling the shell, it may be a good idea to plug in the mouse to ensure the new fan spins and blows in the correct direction (upwards). Testing the DPI adjustment button and color changing scroll wheel will also test that the ribbon cable has been correctly reinstalled.
  4. Marsback Zephyr Pro Fan Replacement, Reassembly Tips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marsback Zephyr Pro Fan Replacement, Reassembly Tips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pulling up gently on the cable can help slide the locking pieces unto place. Pay attention to the seam between the top/bottom shells.
    • Once the seam is flush, the shells are aligned and can be reattached with the screws under the rear skate.
Stephen Smith
crwdns2935283:010/18/21crwdne2935283:0
305 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 161
