Marine Air Passport II Control Board Compressor Relay Replacement
  1. Marine Air Passport II Control Board Compressor Relay Replacement, Compressor Relay: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Marine Air Passport II Air Conditioning unit uses a mechanical relay for the compressor. The relay will eventually fail resulting in the contacts welding together and the compressor and water pump running continuously, or failing to run. Replacing the relay is a simple fix.
  2. Marine Air Passport II Control Board Compressor Relay Replacement, Desolder the existing  relay: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the locations marked in red in the photo to remove the relay. Note that the upper middle hole may not have a relay pin. Be careful not to use excessive heat or damage the PCB traces.
crwdns2935103:0crwdne2935103:0
Mark Radabaugh
crwdns2935283:006/27/21crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,223
