Marco UP Series Electric Pump Electronic Sensor Replacement
  1. Marco UP Series Electric Pump Electronic Sensor Replacement, Prepare the tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The additional sensor with the joint and the heat shrink tubing is available as a replacement kit on www.marco.it .
    • Kits are only available as a registered user, and can be seen for each pump in their dedicated tab on the page.
  2. Marco UP Series Electric Pump Electronic Sensor Replacement, Cut the plastic tie: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Free the cables by cutting the plastic tie.
    • Don't cut the cables that connect the sensor to the pump.
    • Dont' damage the cables' insulation while cutting the plastic tie.
  3. Marco UP Series Electric Pump Electronic Sensor Replacement, Cut the joint between the sensor and the motor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Cut the joint between the sensor and the motor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pliers to cut the red and black cables before and after the joint.
  4. Marco UP Series Electric Pump Electronic Sensor Replacement, Remove the old sensor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Remove the old sensor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the 17mm wrench to unscrew the sensor.
  5. Marco UP Series Electric Pump Electronic Sensor Replacement, Screw in the new sensor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Screw in the new sensor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Screw in the new sensor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw the new sensor by hand for the initial part.
  6. Marco UP Series Electric Pump Electronic Sensor Replacement, Tighten the sensor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the wrench to tighten it in place.
    • Don't over-tighten the screw!
    • Don't add PTFE tape on the screw: there's already an o-ring to seal the connection and it may cause problems to the non-return valve (check valve) underneath.
  7. Marco UP Series Electric Pump Electronic Sensor Replacement, Check how long you want to strip off the cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the joint as a reference on how much you need to remove.
    • Keep in mind that you want to have as much wire inside as possible, but you want to avoid that the peeled wire exits the joint.
    • Use the cutting plier or (if you have it) the stripping plier to remove the sheath.
    • Try to be careful: you don't want to cut the wires inside, especially on the larger pumps.
  8. Marco UP Series Electric Pump Electronic Sensor Replacement, Insert the heat shrink tubing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Insert the heat shrink tubing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Insert the heat shrink tubing: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the heat shink tubing on both motor's cables.
  9. Marco UP Series Electric Pump Electronic Sensor Replacement, Insert the metal joints: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The cable has to be totally inside the metal joint: if you have a longer peeled cable, cut it a little to have it aligned as in picture.
    • Don't insert the plastic sheath inside the metal joint: it worsens the connection and may cause overheating in the large pumps!
  10. Marco UP Series Electric Pump Electronic Sensor Replacement, Press the metal joint: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Press the metal joint: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Press the metal joint: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start on the motor side, and press the metal joint on the cable.
    • To have a stronger force in closing the joint use the internal part of the plier, as showed in the picture.
    • Proceed with by inserting the other end, the short cable coming from the sensor.
    • Repeat the process also for the other cable.
  11. Marco UP Series Electric Pump Electronic Sensor Replacement, Cover the metal joints with the heat shrink tubing: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Cover the metal joints with the heat shrink tubing: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Cover the metal joints with the heat shrink tubing: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the heat shrink tubing.
    • Make sure that it covers perfectly the joint (it must be centered!) on both ends .
  12. Marco UP Series Electric Pump Electronic Sensor Replacement, Heat the tubes: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Heat the tubes: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat the tubes until they shink on the joint evenly.
    • Don't heat too much: you may melt the cables.
    • If you don't have a heat gun, you may also use a lighter, but don't touch the plastic with the flame: keep some distance.
  13. Marco UP Series Electric Pump Electronic Sensor Replacement, Loop the wires: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Loop the wires: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Loop the wires: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loop the wires as shown in the pictures.
  14. Marco UP Series Electric Pump Electronic Sensor Replacement, Add the plastic strap: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Add the plastic strap: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Marco UP Series Electric Pump Electronic Sensor Replacement, Add the plastic strap: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fix the cables using the plastic strap.
    • Cut the excess of the plastic strap using the cutting pliers.
  15. Marco UP Series Electric Pump Electronic Sensor Replacement, You're done!: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now enjoy your updated sensor!
Marco Spa
crwdns2935283:012/04/15crwdne2935283:0
1.531 crwdns2915208:0crwdne2915208:0
Hello. Does this pumps works the same in horizontal or verItical position?
I have an horizontal installation and we always have air leaks to circuit problems.
Kind regards
Juan Correa - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 4,075
