Remove the air filter cover.
Remove two 5/16 standard nuts under the air cover.
Remove the last two bolts pictured with a 5/32 Allen wrench.
Remove old carburetor and install the new one. Remove the throttle cable and reinstall with needle nose pliers. Tighten throttle cable to carb part #16100-Z0Z-034
crwdns2935229:08crwdne2935229:0
crwdns2947412:05crwdne2947412:0
whats the part number
16100-Z6K-WB3 is the carb i used and worked for a mantis XP tiller.
can't find clutch part NO#
cant find the gasket part number between the carb and the piston
the previous tech ordered a cab 3 months ago still hasn't come in
