Use this guide to clean/replace the air filter on your Manatee V2S Intelligent Clothes Dryer. With a dirty filter, you may experience a loss in performance, and it may make some noise. Be careful of any loose or exposed wires as that also may be an issue. In this guide, we will be using a piece of tape to clean the filter. Make sure the device is completely powered off before taking it apart.
Use a Phillips #0 screwdriver to remove the 3.5 mm screw holding the bottom case to the device.
Cut out about 10 cm of scotch tape.
Turn it over and go around your hand as shown in the image, which lets the adhesive side on the outside. (Because it is easy to remove dust)
Take out the filter.
Tap the dust and particles into the garbage, remove the dust with scotch tape, or replace the filter.
Check for broken/loose wiring and other connections.
