Makita XPH01 LED Light Replacement
  1. Makita XPH01 LED Light Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 LED Light Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 LED Light Replacement, LED Light: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 LED Light Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull out the LED light assembly.
Eric Herwatt
crwdns2935283:010/05/16crwdne2935283:0
1,020 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-4, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-4, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G4
Should I do these steps if my drill is under a warranty?
Richard Williams - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,967
