Makita XPH01 Forward/Reverse Switch Replacement
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Makita XPH01 Forward/Reverse Switch Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
Eric Herwatt
crwdns2935283:010/05/16crwdne2935283:0
1.020 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-4, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-4, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G4
crwdns2942667:0crwdne2942667:0 6,400
