This is a guide detailing the steps to replace the armature.
Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
Unscrew the handle unit until it is removed completely.
Hold the black switch located on the front casing.
Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
Once loose, remove the silver disk and/or your grinding disk.
Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
Remove the cover by lining up the knob on the cover with the notch in face plate.
Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
Slide the back cover down the power cable.
Use a spudger to gently move the brush holder coil to the side.
Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
Remove the armature assembly
Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
Remove the faceplate.
Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
crwdns2935229:05crwdne2935229:0
