Makita DT01 Trigger Switch Replacement
  1. Makita DT01 Trigger Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Makita DT01 Trigger Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Makita DT01 Trigger Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the device down on its side.
  2. Makita DT01 Trigger Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the indents on both sides of the battery.
  3. Makita DT01 Trigger Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
  4. Makita DT01 Trigger Switch Replacement, Trigger Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all six 15mm screws with a JIS1 screwdriver bit.
  5. Makita DT01 Trigger Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top of the plastic drill case
  6. Makita DT01 Trigger Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom of the plastic drill case
  7. Makita DT01 Trigger Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your tweezers to remove the black wire from the motor
  8. Makita DT01 Trigger Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your tweezers to remove the red wire from the motor
  9. Makita DT01 Trigger Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your trigger switch should now be removed from your motor
  10. Makita DT01 Trigger Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your tweezers to remove the red and black wires from the two-pronged plug
  11. Makita DT01 Trigger Switch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your trigger switch is now detached from the device
Victoria Scira
crwdns2935283:002/15/17crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 782
