Follow this guide to remove and replace a worn out clutch drum for a Makita chainsaw.
Some images in this guide may show the chain brake cover removed. You do not need to remove the chain brake cover for this procedure.
Optional tools:
- Chainsaw scrench
Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
Pull the hand guard towards the tubular handle until you hear a click to release the chain brake.
Use a small flathead screwdriver or snap ring pliers to pry and remove the stop ring from the axle.
Slide the flat washer off of the axle and remove it.
Slide the rim sprocket off of the axle and remove it.
Slide the clutch drum off of the axle and remove it.
