Maisto Rock Crawler Truck Circuit Board Replacement
  1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Truck Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Maisto Rock Crawler Truck Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Truck Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Truck Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the driver and bit J1 and remove the 7.7mm Philips screw highlighted.
  5. Maisto Rock Crawler Truck Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take note of which wire is connected at which pin before desoldering. It might help to mark the wires and take a picture.
    • It would be easier to desolder and resolder only one component at a time.
    • Use the soldering iron to desolder all the wires connected to the circuit board.
    Wat about repairing the board I it don't turn or turn on or any other repairing issues
    Edgar Sotelo - crwdns2934203:0crwdne2934203:0
kevin
crwdns2935283:002/10/16crwdne2935283:0
874 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-2, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-2, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G2
crwdns2947412:09crwdne2947412:0
Can you do anything to it to make it stronger are powerful
Matt John - crwdns2934203:0crwdne2934203:0
Yes put a board from a nikko or ez tec in it. The 9.6 volt is the one to find and wire the motors to the single motor output. I think u have to wire one backwards to get both going right way
Mike - crwdns2934203:0crwdne2934203:0
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
pankaj kapatia - crwdns2934203:0crwdne2934203:0
Can any one help as my rc rock crawler is not turning left or right
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
mattilajanne - crwdns2934203:0crwdne2934203:0
What is p/n of Maisto Rock Crawler Truck Circuit Board?
Jiri Vitek - crwdns2934203:0crwdne2934203:0
Hola se conecto batería con sus polo al revés y dejo de funcionar me gustaría saber que parte de la placa se daño
Sergio Rodriguez - crwdns2934203:0crwdne2934203:0
good afternoon my circuit burned the q17 component i can't read the nomenclature to replace it, you could send me a picture i can only read the first 2 characters BH grazie.
marciobarpp - crwdns2934203:0crwdne2934203:0
Where can I find a replacement board for maisto pro series crawler 4ws ?
Brandan Dennis - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 5,915
