This guide will walk you through the process of replacing a worn or damaged tire on a Maisto Rock Crawler.
Identify the tire that may need to be replaced or checked for obstructions.
Use the driver and bit PH2 to remove the 16.1 mm screw.
Remove the tire and determine if the tire is damaged or being obstructed.
