Maingear Vector Laptop Screen Replacement
    • pull off the black bezel around the deges
    • it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
  1. crwdns2935267:0crwdne2935267:0
    • carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
    • pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
    • be careful not to rip the tape
    • the tape is in two vertical strips about an inch from the edge
    • the replacement screen is a lp156wfg(sp)(B2) on the maingear vector mg vctr001 1660ti from 2020
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
djluke mon
crwdns2935283:004/18/22crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 758
