Magic Bullet NutriBullet Rubber Gasket Replacement
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the blending blade lid from the cup.
    I just purchased a 3 pk gasket and tried to instal it with no success ! I have a nutribullet is there any place I can have it install???
    Rose Coltess - crwdns2934203:0crwdne2934203:0
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Magic Bullet NutriBullet Rubber Gasket Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
    I am so bummed out as the rubber gasket just came off and I have tried until I have pain in my hands holding the the tweezers and
    the gasket and the part with the blades . I have only used my NutriBullet once and I am broken hearted. Any sugesstions? HELP
    Naomi Hewlett - crwdns2934203:0crwdne2934203:0
    Yes you are correct…the so called experts are having a lend of you..my NutriBullet is not worth a pinch of $@$*…my wife is not Samson and can’t tighten the base as she is just a normal person…so it leaks every time she uses it…it’s useless and dangerous…
    Stephen Mills - crwdns2934203:0crwdne2934203:0
Geary Yu
crwdns2935283:001/22/15crwdne2935283:0
1.253 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-8, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 19-8, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S19G8
crwdns2935297:013crwdne2935297:0
crwdns2947412:011crwdne2947412:0
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - crwdns2934203:0crwdne2934203:0
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - crwdns2934203:0crwdne2934203:0
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - crwdns2934203:0crwdne2934203:0
Thanks a lot.
Kayla Martin -
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - crwdns2934203:0crwdne2934203:0
The gasket in the Nutribullet has disappeared and I think it was blended into the fruit and veg . I drank half of it before I discovered it. I cannot find out if it is toxic or not. Geraldine
geraldine p - crwdns2934203:0crwdne2934203:0
Are you still with us Geraldine? If so……not toxic.. c.2021
Seriously you may have removed it + forgotten or you may not be seeing it, it blends into the unit.
Rachael Mills -
The rubber gasket keeps popping out after each use. I have to replace it back in every time. Definitely a defect in design with no resolution.
carolyn.komer - crwdns2934203:0crwdne2934203:0
I want to purchase rubber gasket of Magic bullet wonderchef nutriblend 400watt. How do I buy it?
Ferisha Nongkynrih - crwdns2934203:0crwdne2934203:0
I have the original magic bullet with the white gasket rings. One side has a small “cut” as if to fit in a grove- so that’s the side I’ve been trying to put in, but it keeps falling out. I’ve tried a knife to push it in and it won’t screw in tight enough to even blend. I’ve tried the smooth end and the end with cut- any ideas on how to get the gasket back in?
Sheri Sergent - crwdns2934203:0crwdne2934203:0
gasket makes the drink taste like rubber
William Parrish - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 35,937
