Magic Bullet NutriBullet Outside Casing Replacement
  1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Outside Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
  8. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wiggle the outside casing upward until it separates from the powerbase.
    • Hold the ring at the bottom of the powerbase to receive a better grip.
    I used my Nutribullet no more than 15 times, or maybe 20, and only for making smoothies, with almond milk, chunks of fruit, and some ground flax. I never ran the motor for more than 30-40 seconds at a time (even though the one-minute limit was nowhere to be found among the instructions. It just gave out on me. I realize now that it was made to give out after a couple of dozen uses. Now it goes to landfill. I will never again buy ANYTHING at Bed Bath & Beyond. They are in business to sell overpriced schlock.
    Judy Mellow - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Angela Wong
crwdns2935283:001/22/15crwdne2935283:0
1.135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-8, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 19-8, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S19G8
crwdns2935297:013crwdne2935297:0
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - crwdns2934203:0crwdne2934203:0
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - crwdns2934203:0crwdne2934203:0
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - crwdns2934203:0crwdne2934203:0
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 7,862
