crwdns2959928:0crwdne2959928:0 ↓Are there cracks in your casing? This guide will help you replace the casing.
Spudger4.9
Use pliers to grip the gear inside of the top of the device.
Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
Remove the white plastic cable guide.
Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
Remove the three white rubber spacers with the spudger.
Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
