Magic Bullet MB1001B Base Gear Replacement
Jackson Wiley
crwdns2944107:0crwdnd2944107:0Jackson Wileycrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Huk 13, 2022crwdne2944111:0
5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
Is your base gear worn down or broken? This guide will help you replace the base gear.
  1. Magic Bullet MB1001B Base Gear Replacement, Base Gear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Magic Bullet MB1001B Base Gear Replacement, Base Gear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Magic Bullet MB1001B Base Gear Replacement, Base Gear: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
    Can you replace the base gear in a Mini Bullet? I am having a hard time unscrewing it.
    Margaret Bellanger - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Jackson Wiley
crwdns2935283:010/06/15crwdne2935283:0
333 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-13, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 12-13, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S12G13
crwdns2947412:08crwdne2947412:0
I am sure a black plastic piece that held the blades tight has broken off. I found pieces of it. How do I replace that piece and where can I get it? Everything is working fine, the motor is turning. The blade is too loose to stay in place while engaged.
cheryl ockrant - crwdns2934203:0crwdne2934203:0
Mine did while I was using it, looking for the same answer, I don't want to go out and buy a whole new set
Sheila Angeletti - crwdns2934203:0crwdne2934203:0
It can't be that both my sets of blades are bent. Should the clear plastic piece in the turn by hand?
sleepyhobbit - crwdns2934203:0crwdne2934203:0
Mine is on but the motor is working but the blades aren't spinning
Shenieza Singh - crwdns2934203:0crwdne2934203:0
Glued too hard. The old industrial revolution greed trick of having critical parts made of plastic to interface with metal. Programmed obsolescence. Garbage once broken. This guide should be rated difficult.
Chris J - crwdns2934203:0crwdne2934203:0
Hi my master bullet won't work at all , nothing ?? Yes it's plugged in I'm wondering if the 3 white pieces on the base are meant to be removed ? Help
nortonjulie - crwdns2934203:0crwdne2934203:0
My plastic gear is shattered and come out but I can not unscrew the metal bit in the middle to replace the gear. Tried almost everything. Please help.
Bali - crwdns2934203:0crwdne2934203:0
Hi that clear circular plastic piece, mine doesnt turn nor does the fan under the nutribullet .. I think it may be jammed. I took apart the bullet and tried to spin the fan on the underside but it wont budge ! Please help !
mike_browne77 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 104
crwdns2942667:0crwdne2942667:0 21,053
