Magic Bullet MB1001B Activator Replacement
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Magic Bullet MB1001B Activator Replacement, Base Gear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Magic Bullet MB1001B Activator Replacement, Base Gear: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
    Can you replace the base gear in a Mini Bullet? I am having a hard time unscrewing it.
    Margaret Bellanger - crwdns2934203:0crwdne2934203:0
  2. Magic Bullet MB1001B Activator Replacement, Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Activator Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Activator Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black base plate.
  5. Magic Bullet MB1001B Activator Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Activator Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Activator Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Activator Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black base.
  9. Magic Bullet MB1001B Activator Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three white rubber spacers with the spudger.
    White rubber spacer is broke from where to get one in colombon
    anonymous 1603 - crwdns2934203:0crwdne2934203:0
  10. Magic Bullet MB1001B Activator Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
    How is called the cover held by the 3 screws? Can be bought somewhere?
    Nicolas All - crwdns2934203:0crwdne2934203:0
    will U give me feedback? If U have a part # will be great!
    Mine is broken, the rest is perfect! Thanks!
  11. Magic Bullet MB1001B Activator Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor.
  12. Magic Bullet MB1001B Activator Replacement, Activator: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Magic Bullet MB1001B Activator Replacement, Activator: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
    Do you know of anywhere to just buy the activator part for this machine? Thanks
    Izzi - crwdns2934203:0crwdne2934203:0
    Where can I buy the “white plastic activators”?
    Erick Mata-Montero - crwdns2934203:0crwdne2934203:0
Aubree Duran
crwdns2935283:010/06/15crwdne2935283:0
387 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-13, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 12-13, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S12G13
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - crwdns2934203:0crwdne2934203:0
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - crwdns2934203:0crwdne2934203:0
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 9,382
