Unscrew four Phillips #0 screws from the back panel.
Unscrew two Phillips #0 screws from the back panel.
Use a plastic opening tool to pop the right side of the panel.
Remove the tape.
Unplug the cable for the speaker.
Place the back panel gently on the table.
Unscrew the left and the right screws using the ifixit screwdriver.
Now that you removed the screws, you can finally replace the speaker.
