Unscrew four Phillips #0 screws from the back panel.
Unscrew two Phillips #0 screws from the back panel.
Use a plastic opening tool to pop the right side of the panel.
Remove the tape.
Unplug the cable for the speaker.
Place the back panel gently on the table.
After the back panel is placed on the table, you must need to locate the starting button.
It is easily removable and can now be replaced.
