You can change the motherboard of the device by following this guide. When disconnecting the mother board , try to unplug all the wires carefully. Using more force can damaged the wires clips or wires it self.
Unscrew four Phillips #0 screws from the back panel.
Unscrew two Phillips #0 screws from the back panel.
Use a plastic opening tool to pop the right side of the panel.
Remove the tape.
Unplug the cable for the speaker.
Place the back panel gently on the table.
Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
Remove all the electrical tapes from different places as indicated.
Remove the white clip attached with black and white wires.
Unplug the wires by pushing it down and slowly pulling it towards you.
After unplugging the wires, take the motherboard out.
Is there a source for replacement Magellan motherboards?
